Saros Z70
Quick Mapping | Vacuum-Only | Mop-Only | Carpet Cleaning | Crossing Thresholds | Returning to Dock | Mop Drying | |
Chassis Lifted |
Mid-to-High-Pile Carpets
2-4cm Thresholds
Side Brush Lifted | |||||||
Main Brush Lifted | |||||||
Mops Lifted | Mop Detached |
13.78 x 13.9 x 3.14 inches
350 x 353 x 79.8 mm
15.0 x 18.7 x 19.21 inches
381 x 475 x 488 mm
4. As of January 2025, the Saro Z70 is the thinnest model among Roborock's vacuum robots.
16. To boost suction power around pet supplies, please activate the “Pet Supply Deep Cleaning” on the App.
Subscribe now to receive a $10 Roborock voucher for your next robot purchase.
