Back to Top
Start 12th Anniversary Sale
Roborock Qrevo Series
FlexiArm Design™ Side Brush
DuoRoller Riser™ Brush
Hot Water Mop Washing
Intelligent Dirt Detection
Dock Self-Cleaning
Intelligent Voice Assistant
10,000 Pa HyperForce® Suction
Auto Brush and Mop Lifting
Single All-Rubber Brush
7,000 Pa HyperForce® Suction
Reactive Tech Obstacle Avoidance
Auto Mop Lifting
Clean like a Master
Experience elite cleaning with Roborock Qrevo Master. Boasting FlexiArm Design™ for thorough coverage, HyperForce® suction power, a DuoRoller Riser™ Brush, and Multifunctional Dock 3.0. Convenient cleaning is just a call away with built-in Intelligent Voice Assistant, coupled with Reactive AI Obstacle Recognition for smooth and pristine cleanups. Get ready for a new level of ease and efficiency.
FlexiArm Design™ Technology
  • Innovative technology enabling flexible movement for thorough corner and edge cleaning, with extendable side brush and mop.
HyperForce® Cleaning Power
  • Unparalleled cleaning effectiveness with a powerful DuoRoller Riser™ Brush and extreme suction of 10,000 Pa.
Dynamic Hot Water
Re-Wash and Re-Mop
  • Transformative cleaning that utilizes the power of hot water to ensure that the mops are washed thoroughly and floors are left pristine.
Automated Self-Propelled Dock Base
  • The ultimate in convenience with a self-driven motor, effortlessly and automatically rotating the scrapers, keeping the dock base clean.
Built-in
  • Smart voice assistant feature that allows effortless hands-free interaction and control using only your voice.
Reactive AI
  • Advanced artificial intelligence that identifies and navigates around obstacles for efficient and safe cleaning.
Reach Every Corner Effortlessly
Roborock's exclusive FlexiArm Design™ Side Brush and Edge Mopping System offers unparalleled thorough cleaning coverage, leaving behind no dirt by eliminating blind spots.
100 % Edge and Corner Coverage1
0 mm Along the Edge and Corner1
FlexiArm Design™ Side Brush When detecting corners, the side brush swiftly extends and sweeps messes away for deeper cleaning.
FlexiArm Design™ Mop The extendable right-side mop meticulously cleans along edges and dynamically adapts to corners.
0Pa
Double Down on Cleanliness
With 10,000 Pa HyperForce® suction and dual all-rubber counter-rotating rollers, hair, dust, and debris are efficiently captured on various surfaces, like hardwood, tiles, and carpets, providing extraordinary cleanliness.
2x All-Rubber Main Brush
10,000 Pa HyperForce® Suction2
Level Up Your Carpet Cleaning
Experience 99% hair removal from carpets with Roborock Carpet Boost+ System™, ensuring deeper and more rigorous carpet cleaning results.
Carpet Boost
Deep Carpet Cleaning
Vacuum Carpet First
99% Hair Pick-up Rate3
Smooth, Tangle-Free Cleaning
Our dual-rubber spiral brush design makes avoiding tangles a breeze and features concealed scrapers in the cover that easily remove hair from the brushes, effectively preventing hair tangling during everyday cleaning tasks.
Dual Spinning Mops
Leave Floors Impeccable
Get clean floors without the hassle. The dual mops spin while maintaining constant pressure, and humidity, effortlessly lifting stains for easy removal.
200RPM Spinning Speed4
30LEVELS Water Flow Options
Liftable Brush and Mops
Elevate Your Cleaning Experience
For different cleaning tasks, the brush and mops can be lifted automatically to maximize cleaning effectiveness while avoiding stains after a cleanup.
Mops Lifted Brush Lifted Brush & Mops Lifted
10 mm Mop Lifting5
Mops Lifted This is a image This is a image This is a image This is a image
Brush Lifted This is a image This is a image
Vacuum-only This is a image
Mop-only This is a image
Carpet cleaning This is a image
Returning to dock This is a image This is a image
Mop drying This is a image
Your Hassle-Free Cleaning Hub
Experience the upgraded Multifunctional Dock 3.0 with enhanced mop washing and self-cleaning capabilities, delivering a truly hands-free cleaning experience with improved power and intelligence.
This is a image Warm Air Drying
Banish Tough Stains
Effortlessly lift oil stains from mops with 60℃ hot water, ideal for kitchen and dining areas, while also saving time and water. The hot water effectively removes over 99.7% of bacteria on the spinning mops. TUV tested.
99.7% Bacteria Removal Rate6
Upgraded Cleaning Results
Re-Wash While washing the mop, detection assesses the dirtiness of the water to determine if re-washing is necessary for complete cleanliness.
Re-Mop In heavily soiled areas, re-mopping occurs to ensure spotless floors.
Dock Self-Cleaning
Embrace Touchless Cleanliness
With the newly incorporated self-driven cleaning module, the dock base bottom is effectively cleaned by the rotating scrapers, eliminating the need for manual maintenance. All self-cleaning module accessories and the dock base are detachable for easy washing when needed.
Warm Air Drying
Auto Tank Refilling
Detachable Base
Warm Air Drying Dries the mops and dock base completely with 45℃ of warm air, preventing the growth of mold and unpleasant odors.
Auto Dust Emptying Allows for up to 7 weeks without emptying.7
Dries the mops and dock base completely with 45℃ of warm air, preventing the growth of mold and unpleasant odors. Allows for up to 7 weeks without emptying.7 Fills the water tank automatically when needed. Easily remove the dock base for your cleaning convenience.
Say "Hello Rocky" for Help
Simply say "Hello Rocky" to start cleanups, adjust settings based on the cleanup scenario, or call the robot where it’s needed, all hands-free. Enjoy the convenience of voice control, even offline, without needing WiFi or your phone to control the robot.
Clean the kitchen
Just vacuum
Clean here
* The commands shown on this page are used as examples only. The actual performance may vary with use conditions.
This is a image This is a image Start and Pause Cleaning
This is a image This is a image Cleanups by Call
This is a image This is a image Specify Room Cleaning
This is a image This is a image Adjust Cleaning Modes
This is a image This is a image Auto Dust Emptying
This is a image This is a image Mop Washing and Drying
Navigate with Confidence
With structured light and an RGB camera, the robot identifies and avoids 62 object types across 20 categories.8 It swiftly navigates around obstacles, minimizing the need for manual intervention in both bright and dark environments.
62types Objects Recognizable
PreciSense® LiDAR Navigation LiDAR-based navigation creates detailed and accurate maps in real-time to find an optimal route to clean your home.
Smart Suggestions for No-Go Zones For stairs and easy-to-get-stuck places, the robot can detect and suggest them as 'No-Go Zones' so you don't have to worry about it getting stuck or taking a tumble accidentally.
Roborock SmartPlan™ Technology
Smarter Cleaning Guided by AI
Tailored cleaning modes to your habits, room types, and floor materials, Roborock SmartPlan™ intelligently generates cleaning modes, and adjusts settings, and preferences automatically. Enjoy worry-free cleaning with no need for manual mode adjustments.
Clean As You Wish
Temporary Cleaning
Floor Cleaning Customization
Customize cleaning direction by activating “Clean Along Floor Direction” to ensure thorough cleaning along floor seams and minimize scraping; tailor preferences for specific carpets and rugs, choosing to clean, skip, or ignore them accordingly. * The carpet and floor cleaning settings need to be activated manually in the Roborock app.
Custom Cleaning Routines
Always Within Reach
Care for Your This is a image Furry Friends
Video Call Real-time video calls and two-way voice interaction allow you to "talk" with your cute pets in a unique way.
Automatic Pet Recognition
Pet Snaps
Search for the Pet
When approaching kittens or puppies, the robot will immediately stop its main brush, and move aside in advance to prevent frightening your beloved pets. The robot can capture adorable snapshots of your furry friends during cleanups, and is readily available for you to download. The robot can automatically search for pets, finding where they’re hidden. You can also check your pet's location and status when you’re away.
  • Customizable App Features
  • ScratchSafe™ Wheels and Brush
  • Sensient® Sensor Array
  • Adaptive Route Algorithms
  • Child Lock
  • Off-Peak Charging
350 * 353 * 103 mm
340 * 487 * 521 mm
STAY TUNED
1. Certified No.1111280914 by TÜV Rheinland. Actual coverage and distance may vary according to the home environment.
4. Based on internal testing carried out by the manufacturer, when selecting extreme water flow in custom mode, the mops can spin at a maximum speed of 200 rpm.
5. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 10mm.
6. Based on testing carried out by TÜV Rheinland on Staphylococcus aureus and Escherichia coli under default self-cleaning mode, over 99.7% of bacteria on the spinning mops are effectively removed. Test Report number: 244555550b1 002. Actual results may vary according to the home environment.
8. Based on internal testing carried out by the manufacturer, the robot vacuum can see and bypass objects down to as small as 5cm wide, and 3cm tall. Recognition accuracy may vary depending on environmental factors.
