A Clean Sweep.
DYAD PRO
The Dyad Pro brings you the perfect clean, every time. Clean up wet and dry messes in an instant, and experience an entirely new level of cleaning with almost zero maintenance.
Vanquish Wet and Dry Messes with DyadPowerTM DyadPowerTM
Improved Edge-to-Edge Edge-to-Edge Cleaning
RevoBrushTM RevoBrushTM Self-Cleaning & Drying System
Adaptive Cleaning with DirTectTM DirTectTM Smart Sensor
Auto Cleaning Solution Cleaning Solution Dispenser
Easy-to-use App Control App Control
DyadPowerTMThis is a image
DyadPowerTM uses multi-rollers that rotate in opposite directions to ensure that no dirt is left behind.
Clean More with 17,000 Pa 17,000 Pa of Suction Power
Featuring the DyadPowerTM cleaning head with 17,000 Pa1 of suction power, wet and dry messes simply have nowhere to go.
Potted Soil
Tomato sauce
Coffee
Milk
Pet food
Eggs
And many other things
Vanquish Wet and Dry Wet and Dry Messes
Make mess disappear, wet and dry, with the DyadPowerTM cleaning head. With unbelievable suction power and
improved rollers, all mess is picked up, leaving behind the cleanest floor.
It provides cleaning on both sides thanks to a full-length roller and two front rollers sweeping up messes with margins of less than 1mm2.
Edge
Edge
1mm
1mm
Self-cleaning
Automatically transform your rollers from dirty to clean in an instant, without lifting a finger. Any mess made by your dog doesn’t stand a chance with more than 99%3 of dirt being removed from the rollers, thanks to its alternating scrubbing.
Self-drying
Rollers are dried automatically with hot air, which means there won’t be any lingering odors. With noiseless drying mode, the only thing you’ll be hearing is your cat purring.
Cleaning Made Smarter
The Dyad Pro automatically adjusts its cleaning power and water flow for the perfect clean when detecting how dirty the floor is. The on-screen LED indicator tells you where the dirt is so you know where to focus.
with DirTectTM Smart Sensor
Clean Like a Pro with the Auto Dispenser Auto Dispenser
The Dyad Pro uses a cleaning solution dispenser that automatically adjusts depending on floor stains, to give you a perfect clean. 1 small cartridge of cleaning solution supports up to 20 tanks of clean water, lasting up to 600 minutes4.
20 tanks
Water Cleaning Volume
600 mins
Auto Dispenser Duration
App Connectivity
The Dyad Pro easily connects to the Roborock App for your convenience. Need to use the RevoBrushTM Self-Cleaning & Drying System? Need to change the cleaning mode? These options (and more) are a tap away.
Voice Alerts
Durable Design for Longer, Efficient Cleaning
The Dyad Pro uses its battery at a 30% higher efficiency when compared to the Dyad. With such industry-leading battery efficiency, it also allows you to deep clean your entire floor, providing a maximum cleaning range of up to 3,230sqft4, on a single charge.
900 ml
Clean Tank Size
770 ml
Dirty Tank Size
43 min
Battery Life
3,230 sqft
Cleaning Range
30%
Higher Battery Efficiency
Just Roll With It
The rollers rotate bi-directionally to help you easily move the Dyad Pro. At just 4.8kg you can pull and push effortlessly, all while playing around with your pet friends as you clean.
4.8kg
Lightweight Design
Product Album
Product Album
Dyad Pro Dyad
Dyad-Pro Dyad
Multi-rollers
Multi-rollers
1mm Edge Cleaning
2mm Edge Cleaning
Self-Cleaning
App Connectivity
30% Higher Battery Efficiency
43 min Runtime
35 min Runtime
Dyad Pro   vs   Dyad
Dyad-Pro
Dyad Pro
Dyad
Dyad
Multi-rollers
1mm Edge Cleaning
App Connectivity
43 min Runtime
Multi-rollers
2mm Edge Cleaning
Self-Cleaning
35 min Runtime
2. Based on internal testing carried out by the manufacturer, rollers approched 1 mm to edges of walls.
3. According to Roborock's internal experiments conducted with dirt and cat hairs.
4. Based on internal testing using ECO mode. Actual results may vary depending on environmental factors.
