Roborock Qrevo
It’s the simple things.
Play Video
Experience the simple pleasure of a smart cleaning, with Roborock Qrevo. With its powerful features and worry-free technology, the Roborock Qrevo makes maintenance, cleaning, navigation, and operation a simple thing.
Multifunctional Dock
Liftable Spinning Mops
5,500Pa Suction
Smart Navigation
Easy-to-use App
Maintenance
is a simple thing.
Say Goodbye to Dirty Work
Make life simpler with hands-free cleaning thanks to the multifunctional dock, which keeps maintenance to a minimum.
Self-Washing
Self-Drying
Self-Emptying
Self-Refilling
Detachable Base
Spins and scrubs the mop pads along the dock base to keep them clean after every run.
Dries the mops completely with 45℃ of warm air, preventing the growth of mould and unpleasant odors.
Allows for up to 7 weeks1 without emptying.
Fills the water tank automatically for a max mopping range of up to 400 sqm (4305 sqft)2.
Self-Washing
Self-Drying
Self-Emptying
Self-Refilling
Detachable Base
Cleaning
is a simple thing.
Dual Spinning Mops
Watch Stains Disappear Completely
Dual mops spin while pressing down, effortlessly removing stains and leaving you with a spotless floor every time.
200 RPM
Spinning Speed3
Dual Spinning Mops
200 RPM
Spinning Speed3
Auto Mop Lifting
Mop and Vacuum in One Run
Mops automatically lift when vacuuming carpets and returning to the dock so that floors and carpets are cleaned in one go, and no dirty streaks are left behind.
7
MM
Mop Lifting4
Auto Mop Lifting
7
MM
Mop Lifting4
Vacuum Carpet First Supported.
5,500Pa Extreme Suction
Keep the Mess Away
With extreme suction of 5,500 Pa5 dust and dirt are easily captured from different floor types for an improved home cleanup.
All-Rubber Brush
Clean Fast Without Tangles
Say goodbye to tangled hair and hello to effective cleaning with the all-rubber brush, adapting to uneven ground for maximum cleaning efficiency.
Navigation
is a simple thing.
Messy Rooms? No Worries!
The Roborock Qrevo detects and avoids potential hazards easily, so you don't have to worry about picking them up off the floor before it starts cleaning.
Risky Areas? Stay away!
For stairs and easy-to-get-stuck places, the Roborock Qrevo can detect and suggest them as 'No-Go Zones'. That way, you don't have to worry about it getting stuck or taking a tumble accidentally.
PreciSense® LiDAR Navigation
Smarter Than You'd Imagine
Scans quickly to know your home environment and creates detailed maps to find an optimal route to clean your home.
6x Faster
Quick Mapping6
3D
Map Display
Multi-level
Mapping System7
6x Faster
Quick Mapping6
3D
Map Display
Multi-level
Mapping System7
Custom Cleaning Routines
Clean as You Wish
Set cleaning routines on the app to clean the whole house, specific rooms, or regularly used areas like your kitchen.
Voice Control
Just a Call Away
With Amazon Alexa, Google Home, or Apple Siri Shortcuts you can start cleaning your house or specific rooms simply by using your voice. It's super convenient and just a call away.
lightning
30%
Faster Charging
Morning
Night
Quickly resume cleaning with 30% faster8 charging than before and get the most from low energy prices by charging during off-peak hours. Do your bit for the environment.
Off-Peak Charging
Customizable App Features
ScratchSafe™ Wheels and Brushes
Sensient® Sensor Array
Adaptive Route Algorithms
Quiet Cleaning
Washable E11 Rated Air Filter
Roborock Qrevo Dimensions
Robot Vacuum
350*353*96.5mm
340*487*561mm
1. Actual emptying intervals will depend on use habits and environmental factors.
2. Based on internal testing carried out on hard floors with a full clean water tank in the dock using default mode. Actual results may vary, depending on room characteristics.
3. Based on internal testing carried out by the manufacturer, when selecting extreme water flow in custom mode, the mops can spin at a maximum speed of 200rpm.
4. Based on internal testing carried out by the manufacturer, the mops can be lifted up to 7mm.
5. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021/5.11 standards, using Max+ mode with a full battery.
6. Compared to Clean&Mapping mode. Actual results may vary according to the home environment.
7. Up to four floors supported.
8. Compared to Roborock S7. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
