Back to Top
Start 12th Anniversary Sale
A Clean Sweep.
Eliminate both wet and dry messes in a single sweep with the Dyad Air, and enjoy an effortless cleaning experience that requires minimal maintenance.
Vanquish Wet and Dry Messes Wet and Dry Messes
Exceptional Edge Cleaning Edge Cleaning
Adaptive Cleaning with DirTect™ Smart Sensor DirTect™ Smart Sensor
Roborock RevoBrush™ Roborock RevoBrush™ Self-Cleaning & Drying System
Easy-to-Use App Control App Control
Conquer Wet and Dry Messes Wet and Dry Messes
With unbelievable 17,000 Pa1 suction power, all messes, wet or dry, are removed easily, leaving behind the cleanest floor.
Exceptional 3 mm 3 mm
Edge Cleaning
The Dyad Air ensures unparalleled cleanliness right to the edges, thanks to its remarkable ability to handle margins of less than 3mm2.
Convenient Cleaning with
DirTect™ DirTect™ Smart Sensor
Automatically adjusts its cleaning power and water flow for a perfect clean when detecting how dirty the floor is. The on-screen LED indicator tells you where the dirt is so you know where to focus.
Self-Cleaning
Prepare to be amazed as the roller transforms from grimy to pristine in an instant, all with a simple press of the button. The bi-directional alternating scrubbing ensures that over 99%3 of dirt is eliminated from your roller, guaranteeing a spotless finish.
Self-Drying
The roller is dried automatically with noiseless drying mode, which means there won't be lingering odors and you can enjoy the peaceful ambiance.
Self-Cleaning
Self-Drying
App App Connectivity
Easily connects to the Roborock App for your convenience. Need to use the Roborock RevoBrush™ Self-Cleaning & Drying System? Need to change the cleaning mode? These options (and more) are a tap away.
Auto
Cleaning rollers
Empty the dirty water tank
Voice Voice Alerts
Durable Design Durable Design for Longer, Efficient Cleaning
The Dyad Air boasts an impressive cleaning reach of up to 360 sqm (3875 sqft) on a single charge, maximizing efficiency and convenience.
900ml Clean Tank Size
770ml Dirty Tank Size
50min Battery Life4
360sqm(3875sqft) Cleaning Range4
Just Roll With It Roll With It
With a lightweight design of just 4.1 kg, the Dyad Air glides effortlessly across your floor, making cleaning easier for you.
Comparison
Dyad Air Dyad Pro Dyad Pro Combo
Dyad Dyad-Pro Dyad-Pro-Combo
5-in-1 Combo
Single Roller
Multi-Rollers
Multi-Rollers
3mm Edge Cleaning
1mm Edge Cleaning
1mm Edge Cleaning
Roborock RevoBrush™ Self-Cleaning and Drying System
App Connectivity
App Connectivity
App Connectivity
50 min Runtime
43 min Runtime
43 min Runtime (Wet Dry Vacuum)
60 min Runtime (Handvac)
Comparison
Dyad Air   vs   Dyad Pro   vs   Dyad Pro Combo
Dyad-Air
Dyad Air
Dyad-Pro
Dyad Pro
Dyad-Pro-Combo
Dyad Pro Combo
Single Roller
3mm Edge Cleaning
App Connectivity
50 min Runtime
Multi-Rollers
1mm Edge Cleaning
App Connectivity
43 min Runtime
5-in-1 Combo
Multi-Rollers
1mm Edge Cleaning
App Connectivity
2. Based on internal Roborock tests, roller approached 3mm to the edges of the walls.
3. According to Roborock’s internal experiments conducted with dirt and cat hairs.
4. Based on internal testing using Eco mode. Actual results may vary depending on environmental factors.
