Clean bedrooms before bathrooms and kitchen.
          Wash mops right after finishing each room.
            Launcher Widgets
One-click to access custom cleaning routines, start cleaning, and more.
           Apple Watch App
Start cleaning on your Apple Watch without reaching out for your phone.
          High Pile Carpets
Choose to avoid
Entrance Carpets
Go across
Carpet Boost
Boost suction power when on carpets.
Deep Carpet Cleaning
Clean your carpet twice for each room.
Vacuum Carpet First
Vacuum carpet first with a dry mop. Then start to mop.
        350 * 353 * 96.5 mm
340 * 487 * 521 mm
        Customizable App Features
ScratchSafe Wheels and Brushes
Sensient Sensor Array
Adaptive Route Algorithms
Quiet Cleaning
Washable E11 Rated Air Filter
1.Certified by TUV Rheinland. Certification ID: 1111277404
2. Based on Roborock internal testing, selecting extreme water flow in custom mode. Actual results may vary depending on usage conditions.
3.Based on Roborock internal testing, the mopping modules can be lifted up to 10mm. Actual results may vary depending on usage conditions.
4.Available in Roborock App with manual settings.
5.Based on Roborock internal testing under Max+ mode with a full battery according to IEC 62885-2:2021/5.11 standards. Actual results may vary depending on usage conditions.
6.Room types need to be set manually in Roborock App. The actual sweeping and mopping mode is automatically determined based on the home environment and historical cleaning behavior, and the actual cleaning mode shall prevail.
7.The "Clean Along Floor Direction" function needs to be set manually in Roborock App. The actual settings may vary depending on the app version.
8.Carpet cleaning strategies need be set manually in Roborock App.
9.Based on Roborock internal testing. Actual results may vary depending on usage conditions.
10.To achieve intelligent auto-empty, auto-empty frequency needs to be set to High on APP.
11.Based on Roborock internal testing, actual emptying intervals may vary depending on cleanliness conditions.
12.Certification No. SHFT230300005371 by SGS Testing. Actual results may vary depending on usage conditions.
13.Based on Roborock internal testing. Actual results may vary depending on environmental conditions.
14.Compared to the Roborock S7. Based on Roborock internal testing. Actual results may vary according to the home environment.
15.Based on Roborock internal testing compared to Clean & Mapping mode. Actual results may vary depending on environmental conditions.
16.Certified by TUV Rheinland to comply with ETSI EN 303 645. Certification ID: 1111265626
