Back to Top
Start 12th Anniversary Sale
Qrevo Curv 2 Flow
Let's Rock, and Roll
Buy Now
SpiraFlow Real-Time Self-Cleaning Mop
A Fresh Mop, Every Time
Qrevo Curv 2 Flow
2.5X Boosted Mopping Pressure¹
The Ultimate Solution for Hard Floor Spills
Qrevo Curv 2 Flow
Innovative Roller Shield
Carpets? We’ve Got It Covered
Qrevo Curv 2 Flow
Edge-Adaptive Roller Mop
Closer to Every Edge
Qrevo Curv 2 Flow
20,000 Pa HyperForce® Suction²
Tackles Tough Messes with Unmatched Power
Qrevo Curv 2 Flow
Certified Dual Anti-Tangle System
No Tangles. No Worries³
Qrevo Curv 2 Flow
The Brand-New Multifunctional Dock
Experience Elevated, Hassle-Free Convenience
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Keep Your Floor Clean, Every Time
Powered by 220 RPM⁴ high-speed rotation and enhanced downward mopping pressure, the roller mop scrubs deep into spills and high-traffic messes with a continuous supply of fresh water. A precision scraper removes excess moisture and channels dirty water into the wastewater tank, keeping the roller fresh every time.
Step 1
Step 2
Step 3
Step 4
Hydrates
Eight precise hydration points evenly distribute clean water across the roller, ensuring full-width, continuous washing.
Moisture Control
A built-in precision scraper removes excess water to prevent drips and streaks, keeping the roller damp for efficient mopping.
Instant Powerful Mopping
A motor-powered roller spins 220 RPM⁴ with boosted downward mopping pressure, effortlessly lifting wet spills and stains from your floors.
Clean and Collect
The system lifts dirt and debris with a precision scraper, filters out larger particles, and safely stores all dirty water in a separate tank. This enables every pass is as fresh as the first, with no risk of cross-contamination.
One Pass, Complete Clean⁵.
Unlike conventional mops that may smear dirt around, our design keeps the roller continuously refreshed with clean water—leaving your floors cleaner, fresher, and more hygienic in a single pass.
Bacteria Removal Rate⁶
Qrevo Curv 2 Flow
Antibacterial Roller⁷
Deep Like a Pro
With 2.5× stronger mopping pressure¹, it effortlessly lifts tough stains from hard floors. By mimicking the power of human hands, it tackles stubborn grime for a deep, thorough clean. Ideal for wet messes⁵ like ketchup, coffee spills, or muddy pet prints, it leaves floors spotless—freeing you from tedious mopping.
2.5X
Boosted Mopping
Pressure
Ketchup Stains
Coffee Spills
Cola Splashes
Mud Spots
Ketchup Stains
Coffee Spills
Cola Splashes
Mud Spots
Qrevo Curv 2 Flow
270 mm Extra-Wide Roller
Engineered for coverage without compromise, the extra-wide design cleans more floor in each pass, reducing cleaning time while minimizing streaks and wheel marks. Ideal for open living rooms and long hallways, it lets you sit back and enjoy a smooth, effortless clean.
Qrevo Curv 2 Flow
Born to protect your carpet
As the robot approaches your carpet, the roller lifts to avoid contact, while the Innovative Roller Shield automatically deploys, forming a physical barrier that blocks moisture and dirt. This multi-layer safeguard ensures true wet-and-dry separation, keeping your carpets dry and clean with ease.
Qrevo Curv 2 Flow
Lifting Up to
15 mm⁸
The roller automatically lifts up to 15 mm, protecting carpets from moisture.
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Smart Strategy for Every Carpet⁹
Qrevo Curv 2 Flow
Want to deep-clean carpets or avoid them entirely? One tap is all it takes. Your robot adapts automatically: stronger suction when cleaning carpets with the mop lifted, or precise edge-cleaning to skip rugs and keep them dry. You're in control of every room, every rug, every time.
Qrevo Curv 2 Flow
Reaching Edges Everywhere
The Edge-Adaptive Roller Mop extends with precision to clean within just 10 mm of edges, ensuring thorough coverage. Its innovative design sweeps away dust and grime from hard-to-reach areas such as wall bases, furniture corners, and skirting boards—helping you maintain a cleaner home with less effort.
Edge Sweeping¹⁰
<10mm
Edge-Close Mopping¹⁰
Qrevo Curv 2 Flow
Along Furniture
Qrevo Curv 2 Flow
Along Chair Legs
DirTect™ Technology
Know the Mess. Adapt the Best.
Powered by AI dirt recognition, our adaptive cleaning system instantly identifies the type of mess in its path. For heavy dust, it boosts suction to capture every particle. For spills and wet stains, it switches to mop-only mode, lifting both the side brushes and main brush to prevent cross-contamination. From fine debris to stubborn liquid messes, it applies the perfect cleaning strategy every time.
For Dry Debris
For Wet Messes
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Easy Maintenance
The roller, scraper, dirty water tank, and other key components are designed for quick removal, making routine cleaning and maintenance simple and hassle-free.
Qrevo Curv 2 Flow
The Roller Mop
The Dirty Water Tank
The Dirty Water Channel
The Dock Base
The Roller Mop
The Dock Base
Qrevo Curv 2 Flow
With powerful 20,000 Pa HyperForce® suction², the Qrevo Curv 2 Flow tackles the toughest cleaning challenges—from deep carpets to stubborn floor gaps—ensuring your home stays impeccably spotless.
20,000 Pa
Max Suction Power²
Say Goodbye to Tangles,
Hello to Clean Floors
Say Goodbye to Tangles, Hello to Clean Floors
Discover Roborock’s advanced Dual Anti-Tangle System, featuring a main brush and dual side brushes engineered to handle debris—from pet fur to hair strands. Enjoy a truly tangle-free, hassle-free cleaning experience with minimal brush maintenance.
Qrevo Curv 2 Flow
DuoDivide™
Main Brush
Hair Tangling Rate¹¹
Hair Removal Rate¹²
Qrevo Curv 2 Flow
Dual Lifting Arc
Side Brushes
Hair Tangling Rate¹³
Simple, Effective, and Hassle-Free
Qrevo Curv 2 Flow
New Cleaning Tray for a Cleaner Roller
Effortlessly clean your roller mop with the upgraded cleaning tray. Its unique design keeps clean and dirty water separate to prevent cross-contamination, while fully soaking and scrubbing the roller in both directions for a deep, thorough clean.
75°C High-Temperature Mop Cleaning
Our Brand-New Multifunctional Dock helps loosen stubborn dirt, food residue, and greasy stains from the roller. With every wash, the roller mop is refreshed more effectively, supporting a deeper, more hygienic floor clean.
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Up to
75℃¹⁴
Qrevo Curv 2 Flow
99%
Bacteria Removal Rate¹⁵
Dirt levels are continuously monitored during mop washing, automatically adjusting wash duration and triggering an extra mopping pass in areas with heavier dirt accumulation.
55°C Warm Air Drying
Dries the mop and dock base thoroughly with 55 °C warm air¹⁶, preventing mold growth and unpleasant odors.
Allows up to 65 days¹⁷ of use without manual emptying.
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Whole-Home Wellness, From Start to Finish.
Every clean, every cycle—designed for sensitive users and healthier homes. Certified¹⁸ safe for infants and pets.
Qrevo Curv 2 Flow
Accurate Object Recognition,
Day or Night
Day or Night
200+
Types of Objects Recognized¹⁹
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
​Your privacy
​is Our Top Concern
Built with privacy at the core, Qrevo Curv 2 Flow is TÜV-certified to ETSI EN 303 645, the leading cybersecurity standard for consumer IoT devices. Camera functions are switched off by default and activated only with your permission.
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
PreciSense® LiDAR Navigation
Tailored for the Best Route
The PreciSense® LiDAR Navigation System scans and creates detailed maps in real time, determining the most efficient cleaning route for a thorough and time-saving clean.
6x Faster²⁰
Quick Mapping
3D
Map Display
Multi-Level²¹
Mapping System
Tap, Tap, Clean
Roborock SmartPlan™ 3.0
From recognizing room types to tracking usage habits, SmartPlan 3.0 tailors every session—boosting suction when needed and rewashing when it matters.
Pet-Friendly Intelligence
Keep tabs on your furry friend with real-time video calls, automatic pet recognition, photo captures, and smart pet tracking.
Simply say “Hello, Rocky” to start cleanups or adjust settings—no need to lift a finger. Your intelligent voice assistant is always ready to help, even offline.
Matter Protocol
With Matter protocol support²², effortlessly control your robot vacuum and other smart devices—no compatibility concerns. Enjoy the ease of a fully connected home.
Smart Return-to-Wash Strategy
The robot dynamically returns to the dock based on real-time water usage, ensuring efficient cleaning while minimizing unnecessary trips.
Easy Wi-Fi Management
Store up to 5 Wi‑Fi profiles in your robot, ensuring it always stays connected—perfect for large homes and multi-router setups.
One Tap to AI-Driven Cleaning
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Automatically performs a vacuum-then-mop routine in rooms that haven't been cleaned for over 30 days.
Automatically deep cleans rooms that haven't been cleaned in a while.
Reduces power and noise during Do-Not-Disturb periods.
Automatically re-washes the mop after cleaning kitchens and bathrooms or following a second mopping pass.
Closer to Your Furry Friends
Video Call
Real-time video calls and two-way voice interaction let you connect with your pets in a fun and unique way.
Qrevo Curv 2 Flow
Pet Snaps
The robot can capture adorable snapshots of your furry friends during cleanups, which you can easily download and enjoy.
Qrevo Curv 2 Flow
Automatic Pet Recognition
When approaching kittens or puppies, the robot instantly stops its main brush and moves aside to avoid startling your pets.
Qrevo Curv 2 Flow
Search for the Pet
The robot can automatically locate your pets, even when they're hiding. You can also monitor your pet’s location and status while you're away.
Qrevo Curv 2 Flow
Video Call
Qrevo Curv 2 Flow
Pet Snaps
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Search for the Pet
Qrevo Curv 2 Flow
Qrevo Curv 2 Flow
Say “Hello Rocky” for Help
  • "Clean here"
  • "Just vacuum"
  • "Clean the kitchen"
Works Great with
Qrevo Curv 2 Flow
Third-Party Voice Control
Qrevo Curv 2 Flow
Fully charged
Qrevo Curv 2 Flow
After Meals
Launcher Widgets
Qrevo Curv 2 Flow
Apple Watch App
Key Specs
Roborock Qrevo Curv 2 Flow
353*353*119 mm
450*450*450 mm
*Images and videos are for illustration purposes only and may not exactly represent the product. The app interface is subject to change without notice.
1.Compared to the Roborock Qrevo Curv with mopping pressure up to 6N. The current model delivers mopping pressure up to 15N, based on internal testing conducted by the manufacturer. Actual performance may vary depending on home environments.
2.Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021/5.11 standards, using Max+ mode with a full battery. Actual results may vary depending on environmental factors.
3.Certified No.PT/25/GEN/0458 and No.PT/25/GEN/0459 by SGS. Actual results may vary according to the home environment.
4.Based on internal testing carried out by the manufacturer, when selecting extreme water flow in custom mode, the mop can spin at a maximum speed of 220 rpm. Actual results may vary depending on environmental factors.
5.Based on internal testing by the manufacturer, the roller mop achieved up to a 100% removal rate of coffee spills, milk, ketchup, and wet muddy spots in a single pass. Actual results may vary depending on environmental conditions.
6.Based on testing carried out by TÜV SÜD, over 99.99% of Escherichia coli, Staphylococcus aureus and Klebsiella pneumoniae on the roller mop is effectively removed. Certification No.704012507644-00. Actual results may vary according to the home environment.
7.Tested by SGS in accordance with GB 21551.2-2010 Antibacterial and Cleaning Function for Household Appliances, the antibacterial rate against Klebsiella pneumoniae ATCC4352 reached over 99.99% (Test Report No. GZF23-017936-06). Actual results may vary depending on the home environment.
8.Based on internal manufacturer testing. Actual results may vary depending on environmental factors.
9.Carpet cleaning settings need to be manually enabled and selected in the Roborock app.
10.Certification No. CN25TVTM001 by TÜV Rheinland. Actual results may vary depending on usage conditions.
11.Certified No.PT/25/GEN/0458 by SGS. Actual results may vary according to the home environment.
12.Certified No.PT/25/GEN/0459 by SGS. Actual results may vary according to the home environment.
13.Certified No.PT/25/GEN/0457 by SGS. Actual results may vary according to the home environment.
14.Based on internal testing carried out by the manufacturer. The stated 75°C refers to the temperature measured at the internal heater output. Actual performance may vary depending on environmental conditions.
15.Based on testing carried out by TÜV Rheinland on Escherichia coli under default self-cleaning mode, over 99% of Staphylococcus aureus and Escherichia coli from the roller mop is effectively removed. Certification ID: 0000088982. Actual results may vary according to the home environment.
16.Based on internal testing carried out by the manufacturer, the air at the base's outlet during drying can be heated up to 55°C under standard room temperature. The actual temperature may vary due to environmental factors.
17.Based on internal testing carried out by the manufacturer. Actual emptying intervals will depend on usage habits and environmental factors.
18.Based on testing carried out and certified by TÜV SÜD. Actual results may vary depending on the home environment. Certification ID: No.704012507644-00 and No.704012506394-00.
19.Based on internal testing carried out by the manufacturer, the robot vacuum can see and bypass objects down to as small as 5cm wide and 3cm tall. Recognition accuracy may vary depending on environmental factors.
20.Compared to Clean&Mapping mode. Actual results may vary according to home environment.
21.Up to four floors supported.
22.The Matter protocol will be available through an upcoming OTA. Please stay tuned for the latest updates.
