Back to Top
Start 12th Anniversary Sale
Saros 20
Beyond Vision. Beyond Limits.
Buy Now
Saros 20 is engineered to master every home environment. The new AdaptiLift™ Chassis 3.0 conquers 1.77 + 1.69 inches thresholds. With StarSight™ Autonomous System 2.0, it maps faster, positions more precisely, recognizes obstacles with greater accuracy, and also slides into lower spaces. With its triple liftable structure, dual anti-tangle system, and the brand new RockDock®, smarter, hands-free cleaning becomes effortless.
Up to 3.46 inches Double-Layer Threshold Crossing¹
Advanced Vision System for Precise Mapping and Obstacle Recognition
Power Suction & Dual Anti-Tangle System
Ensures Zero Hair Tangling with 36,000Pa Hyperforce® Suction & Dual Anti-Tangle Design²
error
FlexiArm™ Technology
Engineered for 100% Cleaning Coverage in Edges and Corners³
Brand New RockDock®
Convenient Hands-Free Maintenance
Intelligent Roborock APP
It Sees,
It Rises,
It Conquers.
Seeks the Optimal Ways to Conquer Thresholds
Up to
1.77+1.69
inches
Double-Layer Threshold⁴
An advanced vision system, adaptive algorithms, and a main wheel + auxiliary wheel + climbing arm lifting structure allow the robot to analyze, test, and memorize the best way to cross thresholds—ensuring uninterrupted cleaning across every room.
Industry-First⁵ Dynamic Cleaning for Up to 1.18 inches Carpets
Experience industry-first dynamic chassis elevation. Intelligently adjust the body height to maintain optimal suction and ensure deep cleaning performance across carpets with pile height up to 1.18 inches⁶.
Prevent Getting Stuck
The robot automatically elevates its chassis or independently adjusts its front, rear, left, or right sides to free itself if it gets trapped.
No Space too Tight,
No Place Unreachable
Low-Clearance Navigation Down to 3.13 inches
Slides Smoothly into Lower Spaces
Equipped with the next-gen StarSight™ Autonomous System 2.0, the Saros 20 achieves a remarkably slim profile, effortlessly navigating under sofas and beds as low as 3.13 inches with advanced localization and mapping capabilities*.
*The body height of the robot vacuum is 3.14 inches. Due to slight vertical flexibility in the front structural components, the robot may achieve limited passive compression when entering low-clearance spaces, allowing access down to 3.13 inches. However, please note that scraping may occur. Actual performance may vary depending on environmental conditions.
Extends to Clean Toe-Kick Areas*
Identifies toe kick areas as low as 0.79 inches⁷ and extends FlexiArm™ Arc Side Brush to sweep hidden dust away.
Clean Beyond Curtains*
Crosses marked curtains with ease—reaching hidden spaces behind for a complete clean.*
*Users should manually mark the location of the curtains on the map through the Roborock app to trigger this function. Actual results may vary depending on environmental factors.
Its Vision Sees
Beyond the Future
The Next-Gen 3D Sensing
Premium navigation and obstacle avoidance technology ensure precise mapping, superior coverage, and enhanced object recognition—whether it's cables, pets, or unexpected barriers.
    Navigation System
  • 21 x
  • 300+
    Types
  • Precision Edge Cleaning Along Obstacles
  • Improved Sampling Frequency than LDS⁸
  • of Recognizable Obstacles⁹
DirTect™ Technology
Stain-Target AI Cleaning*
The robot detects stain types through its RGB camera and adapts cleaning strategies automatically—boosting suction for coffee powder, cat litter, or switching to mop-only mode for liquids waste. No mess is too tough to conquer.
Elevates and Adapts
Liftable Main Brush and Mops
Intelligent Adjustment for Every Scenario
Dynamically adjusts the chassis, main brush, and mop height based on cleaning mode—ensuring optimal contact, coverage, and performance across every surface.
Clean Carpets
Vacuum Only
Mop Mode
Clean Carpets
Main brush lowered & stabilized*
Clean Mid-to-High Pile Carpets
Usual Cleaning Path
Mop detached
Chassis lifted
Mop lifted
Chassis lifted
*Works only if users select “Deep Carpet Cleaning” manually in the Roborock app.
Other carpet cleaning settings should also be manually enabled and selected in the Roborock app.
Vacuum Only
Mops detached
Main brush lowered
Mop Mode
Mops lowered
Main brush lifted
Next-Level HyperForce®
Suction Power
Digital Motor¹⁰
An ultra-powerful digital motor engineered for exceptional cleaning performance.
No Stuck, No Fuss
Zero Tangles, Guaranteed
Easy-to-Maintain
Omni-Wheel
FlexiArm™ Arc
Side Brush
Hair Tangling Rate¹³
DuoDivide™
Main Brush
Hair Tangling Rate¹¹
Hair Removal Rate¹²
No more brush maintenance with the new anti-tangle system on the main brush and side brush that expertly handles long hair and is optimized for pet-friendly environments.
Rolling for a Deeper Clean
200 RPM Dual Spinning Mop¹⁴
Adjustable Downward Pressure
When tough stains are detected, the robot automatically increases downward pressure by lifting its Omni-Wheels to press the upgraded mops harder for deeper scrubbing, better stain removal, and improved water-mark cleaning.
Ordinary Mopping
8N
Downward Pressure¹⁵
Tough Stains Detected
13N
Downward Pressure¹⁶
Roborock's exclusive FlexiArm™ Technology enables the side brush and side mop to reach into hard-to-clean crevices and along walls, delivering unmatched edge-to-edge mopping performance and full perimeter coverage.
Edge and Corner Coverage¹⁷
0 inches
Along the Edge and Corner¹⁸
It cleans,
Then It cleans itself.
Brand New RockDock®
Experience the Pinnacle of Hands-Free Maintenance
212℉ Hot Water Mop Washing
212℉ Hot Water Dock Self-Cleaning
Dust Bag
Fresh-Air Drying
Auto Mop
Removal
Smart Re-Wash
& Re-Mop
131℉ Warm
Air Drying
Warm Water Tank Refilling
Auto Dust
Emptying
Auto Detergent Dispenser
2.5-Hour Fast Charge
212℉ Hot-Water Mop Bi-Directional Washing
Using up to 212℉ hot water, RockDock® helps loosen stubborn dirt, food residue, and greasy stains from the mop pads. With every wash, mops are refreshed more effectively—supporting a more thorough and hygienic floor clean.
Up to
212℉
Hot-Water Mop Washing¹⁹
Hot-Water Mop
Washing¹⁹
Bacteria Removal Rate²⁰
Bacteria Removal
Rate²⁰
New Cleaning Tray with New Soaking Mode*
Less Maintenance Needed For the Cleaning Tray²²
The upgraded one-piece cleaning tray increases mop coverage and water capacity for deeper washing, quieter cycles²¹, and self-cleaning maintenance—no disassembly needed.
Automatic Mop Detachment
Transition seamlessly from hard floors to carpets with an auto-detaching mop. When vacuum-only or carpet-first modes are activated, the mop is intelligently detached to avoid moisture transfer and keep carpets dry, fluffy, and fresh.
Other Features
The dock base stays hygienic with up to 212°F²³ hot water and the self-cleaning module, reducing manual maintenance.
Intelligent Dirt Detection for Re-Washing & Re-Mopping
Dirt levels are continuously monitored during mop washing, adjusting the wash duration and triggering an extra mopping pass for areas with more dirt.
131℉ Warm Air Drying
Dries the mops and dock base thoroughly with 131℉²⁴ of warm air, preventing the growth of mold and unpleasant odors.
Warm Water Auto-Refilling
Automatically refills the robot's water tank with warm water when needed.
Provides up to 65 days²⁵ without manual emptying.
Fresh-Air Dust Bag Drying
Ambient airflow dries residual moisture in the dust bag, reducing odors and keeping the dock fresh.
2.5-Hour Fast Charging
Save time with 2.5-hour fast charging, now over 40% faster than before²⁶.
Detachable Dock Base
Fully detachable dock base for easier washing when needed.
Roborock APP
The Brain Behind Every Clean
Carpet Cleaning
Want to deep clean carpets or skip them entirely? One tap is all it takes. Your robot adapts automatically—boosting suction on carpets with the mop lifted, or following precise edge-cleaning paths to avoid rugs and keep them dry*. You're in control of every room, every rug, every time²⁷.
Roborock SmartPlan™ 3.0
Roborock SmartPlan™ 3.0 automatically recognizes room types, learns your cleaning habits, and selects the optimal cleaning strategy for you—boosting suction when needed, rewashing the mop as required, and lowering power to reduce noise during Do-Not-Disturb periods.
Pet-Friendly Intelligence
Closer to Your Furry Friends
Automatic Pet Recognition
Pet Snaps
Track Your Pet
Video Call & Cruise
Pet Snaps
Track Your Pet
Video Call & Cruise
Everyday Features
This is a image loading=
Built-in Voice Assistant
Third-Party Control
Matter Supported. Automate routines and control all your devices from a single platform. Also compatible with Alexa, Siri, and Google Home.
Your privacy, our top priority.
Key Specs
Saros 20
Saros 20
353 x 350 x 79.8 mm
381 x 475 x 488 mm
Weight
Saros 20
5.05 kg
10.54 kg
1. Based on internal testing by the manufacturer, under test conditions where the first threshold height does not exceed 1.77 inches, the gap depth between the two thresholds is greater than 4.72 inches and does not exceed 5.51 inches, and the second threshold height does not exceed 1.69 inches, the robot is capable of crossing double-layer thresholds with a combined height of up to 3.46 inches. Actual performance may vary depending on environmental conditions and actual user usage.
2. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
3. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
4. Based on internal testing by the manufacturer, under test conditions where the first threshold height does not exceed 1.77 inches, the gap depth between the two thresholds is greater than 4.72 inches and does not exceed 5.51 inches, and the second threshold height does not exceed 1.69 inches, the robot is capable of crossing double-layer thresholds with a combined height of up to 3.46 inches. Actual performance may vary depending on environmental conditions and actual user usage.
5. Based on Roborock’s internal R&D records and available public information, this feature is powered by Roborock’s AdaptiLift Chassis 3.0—the industry’s first mass-produced liftable chassis system with three-wheel control, launched in Q3 2024. The dynamic carpet cleaning capability was officially introduced in Q3 2025.
6. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
8. Based on internal testing by the manufacturer according to the LDS sampling frequency calculation method.
9. Based on internal testing carried out by the manufacturer, the robot vacuum can see and bypass objects down to as small as 0.79 inches wide and 0.79 inches tall. Recognition accuracy may vary depending on environmental factors.
10. Based on internal testing of the digital motor under specific conditions. Actual results may vary depending on product configuration and usage conditions.
11. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
12. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
13. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
14. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
16. Based on internal testing by the manufacturer. The maximum downward mopping pressure is achieved when the “Deep Cleaning for Heavy Dirt or Stains” function is manually enabled in the Roborock app. Actual performance may vary depending on environmental conditions.
17. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
18. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
19. Based on internal testing by the manufacturer. The water at the clean water dispensers of the base can be heated up to 212°F under standard atmospheric pressure (1 atm, 101.3 kPa) at room temperature. Actual temperatures may vary depending on environmental conditions such as altitude and atmospheric pressure.
20. Based on testing carried out by TÜV Rheinland under default self-cleaning mode, over 99.99% of bacteria on the spinning mops are effectively removed. Actual results may vary according to the home environment.
21. Based on internal testing carried out by the manufacturer. Compared to the results of previous Roborock mop-washing cleaning sessions. Actual results may vary depending on environmental factors.
22. Compared to the cleaning tray of previous Roborock robot vacuums. Actual results may vary depending on environmental factors.
23. Based on testing conducted by TÜV Rheinland. The water at the clean water dispensers of the base can be heated up to 212°F under standard atmospheric pressure (1 atm, 101.3 kPa) at room temperature. Actual temperatures may vary depending on environmental conditions such as altitude and atmospheric pressure.
24. Based on internal testing carried out by the manufacturer, the air at the base’s outlet during drying can be heated up to 131℉ under standard room temperature. Actual temperatures may vary due to environmental factors.
26. Based on internal testing carried out by the manufacturer and compared to the previous Roborock robot vacuums. Actual results may vary depending on environmental factors.
27. This feature is applicable to household carpets with pile heights of 1.18 inches or below, which covers the majority of carpets used in typical homes.
