Back to Top
Start 12th Anniversary Sale
Roborock Qrevo Edge
Elevate Clean, Untangle Life
Introducing Roborock Qrevo Edge, bringing you the best in precision and power. Featuring the Dual Anti-Tangle System and AdaptiLift™ Chassis, it effortlessly prevents hair tangles and seamlessly adjusts to various floor types for thorough, hassle-free cleaning. Boasting 18,500 Pa HyperForce® suction and advanced FlexiArm™ Technology, every corner of your home receives impeccable care. Experience an added edge in home cleaning.
  • Equipped with the DuoDivide™ Main Brush and FlexiArm™ Arc Side Brush, ensuring tangle-free cleaning.
  • Seamlessly adapts to various home environments with smooth movement.
Industry-Leading
  • Delivers unmatched power for a deep and effective clean.
  • Features an extendable side brush and mop for precise cleaning in every corner.
75°C Hot Water
Re-Wash and Re-Mop
  • Intelligently utilizes 75°C hot water to re-wash and re-mop for spotless floors.
Snag-Free, Smooth Cleaning
Breeze Through Tangles
Enjoy seamless, tangle-free cleaning with Roborock Qrevo Edge's revolutionary dual anti-tangle system, featuring both main brush and side brush designed to tackle long hair and pet fur.
Featuring dual parallel short bristle rollers with spiral blades, the DuoDivide™ Brush efficiently channels hairs to the central dustbin inlet, where powerful suction swiftly clears it away. Certified by SGS and TUV, this brush excels with its unmatched cleaning performance and cutting-edge anti-tangle technology, setting a new standard for effortless cleaning.
100% Hair Removal Rate1
0% Hair Tangling Rate2
The innovative arc-shaped asymmetric brush generates centrifugal force during rotation, guiding hairs to the bristle ends and preventing tangling. Certified by SGS and TUV, this design delivers effective, tangle-free cleaning with every pass.
0% Hair Tangling Rate3
Easy-to-Maintain Omni-Wheel The enhanced omnidirectional wheel is paired with a cleaning brush that automatically cleans the wheel during use, simplifying maintenance.
Superior Performance, Beyond Expectations
Boost Your Cleaning Game
The Roborock Qrevo Edge delivers impressive cleaning power with 18,500 Pa HyperForce® suction. Combined with the DuoDivide™ bristle brush, it conquers tough cleaning challenges on carpets and hard floor gaps, ensuring no debris stands a chance.
18,500Pa HyperForce® Suction4
99.5% Hair Removal Rate on Carpet5
Address Every Area
Roborock's exclusive FlexiArm™ Arc Side Brush and Edge Mopping System offers supreme thorough cleaning coverage, leaving behind no dirt by eliminating blind spots.
100% Edge and Corner Coverage6
0mm Along the Edge and Corner6
When corners are detected, the arc side brush quickly extends to sweep away debris, ensuring a deeper clean.
FlexiArm™ Mop
The extendable right-side mop precisely cleans along edges and adjusts dynamically to tackle corners.
Dual Spinning Mops
Achieve Spotless Floors
Enjoy effortless deep cleaning as the dual mops rotate with consistent pressure and humidity, seamlessly lifting and removing stains.
200 RPM Spinning Speed7
30 Levels Water Flow Options
Climb to a New Level of Clean
AdaptiLift™ Chassis
Elevate Your Cleaning Solutions
Transform your cleaning with the industry-first8 AdaptiLift™ Chassis. This cutting-edge system boasts independently adjustable three-wheel control, enabling the chassis to lift by 10mm9 or elevate the front, rear, left, or right sections. Experience unparalleled adaptability to any home environment and achieve optimal cleaning coverage with ease.
High thresholds are no longer a challenge with the AdaptiLift™ Chassis. It automatically lifts the omni-wheel to handle standard thresholds up to 3cm10 and complex double-layer thresholds up to 4cm11, the highest in the industry12, ensuring smooth movement across all surfaces.
Mid-to-Long-Pile Carpet Cleaning
With the AdaptiLift™ Chassis’ 10mm elevation capability, cleaning performance is enhanced on mid-to-long-pile carpets. This feature allows powerful suction to reach deep into carpet fibers, preventing clogging and delivering superior cleaning results for cleaner, more refreshed carpets.
*The mid-to-long-pile carpet cleaning settings need to be activated manually in the Roborock app.
Liftable Brush and Mops
Customized Cleaning for Every Challenge
The brush and mops can be lifted automatically for different cleaning scenarios to maximize cleaning effectiveness while avoiding stains after a cleanup.
Chassis & Mops Lifted Mops lifted Brush lifted Brush & Mops Lifted
10mm Chassis Lifting
10mm Mop Lifting
10mm Mop Lifting13
Mops Lifted This is a image This is a image low-pile carpet This is a image This is a image
Mops & Chassis Lifted This is a image mid-to-long-pile carpet
Brush Lifted This is a image This is a image
Mops Lifted Mops & Chassis Lifted Brush Lifted
Vacuum-only This is a image
Mop-only This is a image
Carpet cleaning This is a image low-pile carpet This is a image mid-to-long-pile carpet
Returning to dock This is a image This is a image
Mop drying This is a image
Engineered for Ease of Use
Multifunctional Dock 3.0
Stress-Free Cleaning Companion
The upgraded Multifunctional Dock 3.0 features 75°C hot water mop washing and self-cleaning capabilities, for an enhanced truly hands-free cleaning experience with improved power and intelligence.
This is a image 75°C Hot Water Mop Washing
This is a image Dock Self-Cleaning with Hot Water
This is a image Warm Air Drying
Exceptional Stain and Bacterial Removal
Effortlessly remove stubborn stains and greasy messes from mops with 75°C hot water14, ideal for kitchens and dining areas. The high-temperature water eliminates over 99.99% of bacteria, ensuring superior hygiene. With three adjustable temperature settings, you're equipped for any cleaning challenge.
99.99% Bacteria Removal Rate15
Superior Cleaning Quality
Re-Wash During mop washing, detection checks the level of dirt on the mops to determine if additional washing is required to ensure thorough cleanliness.
Re-Mop In areas with stubborn dirt and stains, the floors will be mopped a second time to ensure they are thoroughly cleaned. *The automatic re-mopping feature needs to be activated manually in the Roborock app.
Discover Touchless Cleanliness
The dock base is effectively cleaned by the rotating scrapers and hot water, thanks to the incorporated self-driven cleaning module, eliminating the need for manual maintenance.
Easy Handling, Superior Convenience
Warm Air Drying
Auto Tank Refilling
Detachable Base
Warm Air Drying Dries the mops and dock base completely with 45°C of warm air16, preventing the growth of mold and unpleasant odors.
Auto Dust Emptying Allows for up to 7 weeks without emptying.17
Dries the mops and dock base completely with 45°C of warm air16, preventing the growth of mold and unpleasant odors. Allows for up to 7 weeks without emptying.17 Fills the water tank automatically when needed. Easily remove the dock base for your cleaning convenience.
Advanced Capabilities
That Lead the Way
Say "Hello Rocky" for Help
Just say "Hello Rocky" to initiate cleanups, adjust settings for different scenarios, or direct the robot to where it's needed, all hands-free. Enjoy the convenience of voice control without needing WiFi or your phone, even when offline.
"Clean here"
"Clean the kitchen"
"Just vacuum"
*Intelligent voice assistant is available in selected languages, please refer to the Roborock app for more information.
Navigate Any Home Terrain
Equipped with structured light and an RGB camera, the robot detects and avoids 62 types of objects across 20 categories18. It efficiently navigates around obstacles, reducing the need for manual intervention in both well-lit and dim environments.
62types Objects Recognizable
PreciSense® LiDAR Navigation
Pet-Friendly
Delight in This is a image Pet-Friendly Features
Quiet Cleaning Roborock Qrevo Edge features brushless motors and an advanced hardware design that minimize noise during operation. With mopping noise levels as low as 55dB19, it provides a notably quiet cleaning experience, keeping your pets calm and undisturbed.
Video Call Real-time video calls and two-way voice interaction allow you to "talk" with your cute pets in a unique way.
Automatic Pet Recognition When approaching kittens or puppies, the robot will immediately stop its main brush, and move aside in advance to prevent frightening your beloved pets.
Pet Snaps The robot can capture adorable snapshots of your furry friends during cleanups, and these are readily available for you to download.
Search for the Pet The robot can automatically search for pets, finding where they’re hidden. You can also check your pet's location and status when you’re away.
Clean As You Wish
Roborock SmartPlan™ Technology
Tailored cleaning modes to your habits, room types, and floor materials, Roborock SmartPlan™ intelligently generates cleaning modes, and adjusts settings and preferences automatically. Enjoy worry-free cleaning with no need for manual mode adjustments.
Real-Time Cleaning Progress Display
Utilize the app’s dynamic progress bar to effortlessly monitor the robot's cleaning status. Receive real-time updates directly on the homepage, optimizing efficiency and saving time.
Temporary Cleaning
Temporary Cleaning
Always Within Reach
Matter Protocol Step into the Future of Smart Living Unlock new possibilities with the Matter protocol and Roborock Qrevo Edge. Effortlessly control your robot vacuum and other smart home devices with seamless compatibility. Experience the convenience and efficiency of a fully integrated smart home.
  • Customizable App Features
  • Sensient® Sensor Array
  • Adaptive Route Algorithms
  • Child Lock
  • Off-Peak Charging
Roborock Qrevo Edge
352 * 347 * 103 mm
340 * 487 * 521mm
Sign up for product availability alerts, exclusive offers, campaigns, and more.
1. Certified No.PT/24/GEN/0244/1 by SGS. Actual results may vary according to the home environment.
2. Certified No.PT/24/GEN/0243/1 by SGS. Actual results may vary according to the home environment.
3. Certified No.PT/24/GEN/0245/1 by SGS. Actual results may vary according to the home environment.
8. Roborock was the first in the robot vacuum industry to mass-produce a product featuring a liftable chassis system with three-wheel control, officially launching this technology in Q3 2024.
9. Based on internal testing carried out by the manufacturer, the chassis can be lifted up to 10mm. Actual results may vary according to the home environment.
12. Based on research conducted by the manufacturer as of Sept 1, 2024, within the robot vacuum category.
13. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 10mm.
15. Based on testing carried out by TÜV Rheinland on Staphylococcus aureus and Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the spinning mops are effectively removed. Test Report number:CN24N13I 001. Actual results may vary according to the home environment.
